J
jassin000
@hoagtech
I was a little turned off by the down points yes, really the viewing angles.
However the vertical angle isn't bad, its the horizontal angle that is more of an problem.
Being that both players sit directly in front of the screen I hope that isn't going to be a huge issue.
The key points on this monitor for me...
IF so, that would make it more expensive than the entire VLX machine I'd be install it inside.
- QHD resolution should work with OSSC's 1600x1200 pure 5x.
- Freesync should accept syncs outside of 60Hz (my LG TV also dose this so I hope for more of the same).
- Monitor was less than 500$
