tonyt76
New Jersey
Hey guys, recently installed a -001 loom into my Blast City with a Naomi 2. When I try to coin up in a game using the coin switch, credits do not register. If I test the switch using a meter it works fine. What would cause the coin switch not to register?
Mine is wired to pins 5 and 7 of CN9 on the blast io, maybe check that connector?
@ekorz I found the issue. The connector for the coin meter became unplugged under the coin box (white plug).
Do you have both coin meter plugs plugged in? The white & the black?
The coin meter under the coin box? I haven’t been in there really. Looks like there are 4 wires when I remove the little plate though. It’s just a loop of wire so I can’t tone it anywhere, but I’d trust the wiring diagrams that are out there.
Swapping to the 001 loom wouldn’t change any of this stuff though!
