pacoarcade
R1-R4 are 75 ohm (at least in advanced version). It's specified in the BOM pdf included in the zip file.Which resistors correspond to r, g and b. There are 4: R1-R4. I assume one is for sync. Is R4 sync?
Put me down for one if you decide to make and sell these!Making progress on the 3d printed case design. I built it to easily adjust to future layout changes. Also, there is some reinforcement in the case structure for the JAMMA connector and DB15 connectors so they are supported. Feels really sturdy in the hand. Attached with 4 x M3 screws and nuts. I'm using a 3mm light pipe for the power LED. Most of the switches are accessible, I omitted the B4 and LPF for now, but those can be added. I will publish it on Thingiverse once it is completed.
Is the voltage level still safe (under 1.46Vp-p?) if the potentiometers are off? (i.e. turned all the way to the left)RGB outputs from arcade PCB, at levels around 4Vp-p
Pots are wired as a voltage divider, which adjusts the input voltage to the THS7374. As the THS doubles the signal upon output, we're feeding it 1/4 of the voltage at input of what we desire upon output.
The THS can accept full level video signals, up to 1.46Vp-p.
It definitely still looks awesome ... If anybody wants to split the cost of ordering some PCBs (after the new design is finalized), let me know.To tackle the Undamned encoders not fitting side by side, I've shifted the TEST and SERVICE switches to the centre of the DB15s.
My sense of symmetry dislikes this as before the DB15's were perfectly centered but oh well.
Looks like the Sullins EBM28DREH JAMMA connector has gone backorder for now, anyone find a good alternative that fits the minigun right?
