Soulkilla
I used it for my Namco boards, specifically Tekken 3 and Tekken Tag; and I experienced issues with consistency on multi-button presses. For example I play a ton of Jack and one of his main moves requires 1+2 to be pressed at the same time. For my test I was using a RAP4 but did not test with a PS4 controller or PS3 controller (If I'm playing an arcade game my whole purpose would be to use a stick). I was having issues with the execution of the move I described previously and throws (1+3, 2+4). I then wired in a DB-15 port into my RAP4 and have used it since with 0 issues.I mean, I would use the Undamned converter if it was available, but it is not. As I don't really play many 5/6 button games, the only thing that seems interesting from the things you mentioned is the "simultaneous button presses" issue. Could you elaborate on that?I would not recommend using the Brooks Ps3/PS4 adapter for the minigun. First off the adapter has many issues including issues with simultaneous button presses (Throws for instance in Tekken) and has a lack of functionality (Can't save custom reprogrammed button profiles). Also this adapter DOES NOT SUPPORT 5or6 BUTTONS! Even though on Brooks and other websites it claims to support kick buttons it in fact does not. It only it meant to be used with a NeoGeo and limits itself to 4 buttons. Also the instructions you get with the adapter are wrong and Brooks hasn't bothered to fix them in the past 2 years.
The Undamned adapter is what I would recommend but seems current orders are on hiatus for awhile (UD-USB Decoders) .
I have a Brooks converter and it seems to work alright with Minigun, but I haven't really tested it much.
I can say that I have not tested the output of the adapter on a Digital Analyzer for instance, so my observation is through experience and not purely scientific. I really didn't care enough to go farther since I could simply wire my fight stick to a DB15 connector.
