I'm going to skip over all the various testing and research I did to get to this point. We've got two Vewlix VS cabinets. They're designed to use these VS PCB Kits to split the video and audio signal from one Type X2 to both sides and to run two JVS boards, one on each side. My problem is that I can't get the JVS to work for both sides simultaneously with Ultra Street Fighter IV. Obviously USFIV is X3 and not X2, but as far as I know that shouldn't have a profound effect on this, but I could be wrong.
If I have one JVS plugged into the X3, it works as the 1P side. If I plug the second JVS into the first JVS, which is supposed to make one work as 2P and the other as 1P, the second JVS instead becomes 1P and the first JVS does nothing. The USB on the VS PCB Kit is just a pass through.
The only information I've found about this was this thread here. It was mentioned that the game has to support JVS linking, but I would imagine most fighting games would, especially USFIV. Does anybody know if USFIV isn't compatible with JVS linking? Or is there something else I need to do? I've found no setting in the test menu that would help.
I'm on a schedule so I'm getting to the point where I'm just going to wire the 2P side into a JST connector and have everything running off one JVS board, but it'd be a lot easier if I could get this working the way it's supposed to.
