Working on building myself CMVS v2.0 and I want to include the PSU into the enclosure and feed AC directly into the back rather than rely on wall-warts and in-line power bricks.
Why? It's convenient, keeps cable mess down, and a moron friend fried the motherboard in my CMVS once because there are plenty of 12v PSU's that use the exact same 2.5mm barrel plug my 5v CMVS uses. I would like to avoid this in the future.
The PSU I'm thinking is a 5v 7a PSU (I know, overkill on the amps, but it's incredibly compact) from an older model Apple TV, so it's high quality, low heat, and was already shoved inside a super tight enclosure right next to the apple TV motherboard so I imagine it produces relatively low RF interference.
So what I wonder, is interference going to be a problem with the NeoGeo? if I shield it with well am I ok? Is AC current running directly into the CMVS going to be a problem (outside of shoddy workmanship, I know what I'm doing with AC and it will be well protected.)
Here's the PSU next to a MV-1fz
It doesn't have any kind of metal shielding on it, just this plastic wrap around stuff. I was planning to mount it underneath the board with a bit of ventilation (apple TV's have zero ventilation)
Anyone see any issues with this?
