Is there a high voltage component to touch which specifically removes chest hair? Cause I need that =)A little zap is ok. It puts hair on your chest.
That small of a magnet that far from the tube won't have any effect.Stupid question, but does it matter if the screwdriver used to discharge has a magnetized tip? Would it be better to use one without since magnets are bad for CRTs?
Or removes it Either is fine I suppose.A little zap is ok. It puts hair on your chest.
That's exactly what I use. I run the electrical tape all the way down to the tip from the handle, the more the better in my opinion. Wouldn't hurt to do a continuity test from the tip of the screwdriver to the alligator clip you'll connect to ground.Alright, so my Yaton chassis arrived today and I'm getting ready to put together my discharge tool. Are alligator clips crimped on to the ends of the wire and wrapped in electrical tape sufficient? Large flat head screwdriver with a rubber handle, the clip secured by electrical tape on the screwdriver as well, and 10-12 AWG wire? Anything I'm missing?
Yep, those should work. Are you near a Harbor Freight? You can get a bunch of test leads for a few bucks already made.
I am, just figured the "low voltage" wouldn't work correctly. Also not finding electrical insulating gloves at any local place, just standard vinyl/latex gloves. Maybe I'm being too cautious but better safe than sorry.Yep, those should work. Are you near a Harbor Freight? You can get a bunch of test leads for a few bucks already made.
This is what I use, only 18ga but it's worked fine throughout several discharges, might get a lil warm, lol.
https://www.harborfreight.com/18-inch-low-voltage-multi-colored-test-leads-66717.html
Yep, I couldn't find them locally either. They sell them on Amazon.I am, just figured the "low voltage" wouldn't work correctly. Also not finding electrical insulating gloves at any local place, just standard vinyl/latex gloves. Maybe I'm being too cautious but better safe than sorry.Yep, those should work. Are you near a Harbor Freight? You can get a bunch of test leads for a few bucks already made.
Absolutely, it will be fine. I've been discharging with 18ga, not recommended but it works fine.Would these 14 AWG pre-made leads work or do I need heavier wire than 14?
https://www.amazon.com/Alligator-Clips-Heavy-Silicone-Jumper/dp/B07L29V4Z2/
Thanks to you all for your patience with a beginner.
