Last month I got my first Sega Blast City, it sold as “monitor not working”. When I got home and powered it up the monitor worked, the previous owner told me that someone had tried to repair it before, so I wanted to look at it before running it too long so I shut it off.
I disassembled the whole cabinet to clean, remove rust and repaint the affected parts.
After removing the CRT Chassis, I immediately noticed that someone had... "Repaired" it. They have replaced the HOT, one cap and a transistor. All the pads were ripped away.
Warning for Graphic images!!
After tidying that mess, I replaced all the electrolytic capacitors on the board+neck with new Panasonic and Rubycon capacitors.
When I turned the monitor on I heard a POP and a capacitor vented.. I managed to put one on backwards... :/ So I replaced it and turned it on again.
The picture looked great, until after a few seconds when I got into a game. I noticed some horizontal distortion on the bright parts of the picture.
I tried to capture it with a full white picture, you can see it flickering if you full screen the clip and look at the bottom section.
I have checked every cap for the correct rating and polarity, and all the solder joints. I have also reflowed the whole neck board.
I used the MS-2931 manual and Schematic to diagnose the board, but I cannot find any problem.
I've noticed two things: the flyback is making a high pitched noise, and the CXA2055p is getting hot really fast.
Have you ever seen this before? Is this a problem with the tube, yoke or the chassis?
