SOLD Arcade Spring Cleaning: aero psus, cocktail parts, vewlix parts & more
themisterfalcon
Michigan
Tossing the rest of this crap out!
Namco 2X6 JVS IO $65
Vewlix IO Plate $30 SOLD
Vewlix Plate Cover Right $15 SOLD
Original Egret 2 IL Panel $350
SOLD
WEI-YA 3129DB Tri Sync Chassis $150 SOLD
Arcade Projects Jamma Extender $60 SOLD
MK Workshop Mahjong Adapter $30 SOLD
System 16B Rom Board $25 SOLD
Vewlix F CP Sides $30 SOLD
Puzzle and Dragons X3 running Senjin $250 SOLD
Senjin X3 $250
This is a custom build of Senjin Aleste designed to work on the "Puzzle and Dragons" X3. It autoboots into tate mode in 4:3 for use on a 31khz/480 display. Shown running on an Egret 3 with a Sanwa PFX and a TD IO. Any JVS IO is required for controls. This is not a MuLTi. It will not run the Artrax multi. If you are asking this, you are missing the point here.
Does Senxin/Senjin Aleste normally run on TTX3 hardware, or something else? I figure there'll be a home port eventually, but having it in a 31 kHz cab would be pretty sweet. DM
Nope it ran on the ALL.Net P-ras originally. This build was made out of the windows version that was floating around a few years ago.
Senjin unit is now sold though.
