WTB Egret 29 Parts (many needed)
Want To Buy
trashedcabs
WA, USA
I have a gutted Egret 29 that was sitting in a field planned for a restoration likely next year after my current one is finished. Finding ANY of these will significantly reduce the amount of work I need to do remaking or repairing the parts I have now.
In order of importance:
  • Entire wiring harness including control panel harnesses
  • Entire control panel housing assembly (I don't need the control panel itself, I need the actual plastic shell and steel housing with all latches etc)
  • Test/service panel
  • Top and bottom bottom bezel plastic (the plastic pieces the glass sits on)
  • "Egret 29" illumination panel
  • Rear power input/switch assembly
  • Coin mech assembly (bracket etc)
  • Monitor chassis shelf/bracket
Please DM me if you have any of these in ANY condition. Thanks!
All of the connectors are still manufactured except for the exact 56 pin connector. I actually just spent like $400 in wire and connectors and will be making my own harness--will update the post.
Do you have a picture of the cab?
