In The Hunt port coming to NeoGeo?
I can't understand how this is even possible.. the skills of some ppl these days is mindboggeling <3
Interesting feature is to switch the sound from Neo Geo to PS1 via Dip switch.
Hopefully this game will be completed.
"Neo Geo"? Did they rearrange the soundtrack for the Neo Geo? I assume it just has a recording from the arcade.
Not sure if anyone else is working on this already, thought it would be cool to start collecting arts to make physical versions
AES sticker (89mm wide x 84mm high, 2mm radius on the corners)
AES Snapcase insert
MVS Sticker
MVS ShockBox insert
MVS NeoSleeve
Others?
More info filtering out on Twitter/X
The Good
AES mode with fun menus and etc
Unibios support with cheats and etc
Choice of PS1 or arcade music (maybe?)
The compromise
Reduced colour palette (NeoGeo = 4096 colours, M92 = 32bit)
Reduced resolution (NG = 320x224, M92 384x256)
Funnily enough, my shitty, small home town in South Dakota had a local pizza place with a small room in back with arcade cabs and one of them was In The Hunt. Really makes you wonder how many boards are in forever-storage or destroyed. They also had Cabal which is a surprisingly fun trackball game you don't hear about too often. What a nostalgic era.
The Good
The compromise
Less simultaneous sprites onscreen at the same time too, pixel sprite per scanline limit is also lower on the Neo.
