MS9 Curve
VS_Lilith
Ontario
Our shop sold a NAC with an MS9 in it and the customer wanted it rotated to put a 60 in 1 for the time being. After I rotated it though, the monitor developed a large bend on the top right, is this interference with the speaker at the top? Or is there a way I can adjust this on the chassis? Thanks!
SPC15 on the chassis. It's easily adjusted now that the monitor is rotated. Just open the service door and look for the pots on the bottom side of the chassis.
Perfect I'll take a look next I'm in thanks!
Reactions: nem
Perfect, that fixed that really bad curve on the edge, anyway I can fix the curves in the middle of the monitor (top and bottom)
I would also check that the B+ settings are correct. To low B+ will do that to your picture.
From https://gamerepair.info/hardware/35_nanao_ms9_29
B+ Voltage
The main DC supply voltage, B+, can be checked using the TP2 test point. It is located in the center of the PCB, in the corner of the "U" shaped side of the heatsink next to the empty inductor location L505.
The correct B+ voltages are:
15KHz: +76V DC
24KHz: +119V DC
