Help needed to restore original bboards
16bitgium
Belgium
I have two broken cps2 boards laying around. Iwas able to install this openkey but I still get the dreaded purple screen. I think installed everything correctly. I've measured the pins to CN9 top side pins and I have continuity on each pin. Is it possible that installation on my type of board is still slightly different? I tried two boards but both give nothing. The 93646B-6 gives first a little bit of black before going to purple. This vampire hunter does not seem worked on before. The other game does. Is there a way to test the components? What else can I do to try to resolve this issue. Battery hadn’t leaked and I also got a purple screen prior to the installation of the open key. My A board works with other games.
Did you double check the jumper setting, right version and the like? (I believe the open version has different jumper setting than the commercial version so make sure to lookup up the right table)
Pretty new to cps2 . What do you mean difference between open and commercial version?
This is my shell.
And I used these jumper settings from the open key page or do you mean settings on the cps2 board itself?
[td]
1001 1010​
[/td]​
[td]
vphj
vphj
vphjstop
vphj​
[/td][td]
vhuntj
vhuntjr1
vhuntjr1s
vhuntjr2​
[/td][td]
Vampire Hunter: Darkstalkers' Revenge (Japan 950316)
Vampire Hunter: Darkstalkers' Revenge (Japan 950307)
Vampire Hunter: Darkstalkers' Revenge (Japan 950307 stop version)
Vampire Hunter: Darkstalkers' Revenge (Japan 950302)​
[/td]​
This is my shell.
[td]
1001 1010
[/td]​
[td]
vphj
vphj
vphjstop
vphj
[/td][td]
vhuntj
vhuntjr1
vhuntjr1s
vhuntjr2
[/td][td]
[/td]​
If you are 100% sure the open-key jumper points are shortened with good setting tor this game region and it still does not boot make sure there's good connection between A & B board. Give it a good squeeze on each of four connectors.
Commerical = Infinikey, does the same thing but I'm not sure the jumper settings for the games are the same.
Don't go by Cps2 shell go by Rom label (South American Boards also came in green sometimes)
That said the jumper setting looks correct if I'm not mistaken
If you have a ability to read/burn eproms.
I would dump the 03 rom and just verify the crc matches whats in mame for the game. Pretty sure I had a board in the past with the wrong stickers on the eproms.
There is a suicide tester here
https://cps2shock.emu-france.info/download/suicidetesterv2.zip
You run it on a suicided B board and it will help verify the B board is working ok.
Also in your close up picture of the openkey it kinda looks like pins 1 and 2 are bridged together on the attiny chip?
I think in this picture it is clearer I don't think they are bridged:
I dont have an eprom reader/writer. But I think it might be time to buy one. What can you recommend?
Did you do the short circuit with a conductive tool on EXC5 to delete the old key in memory before?
So I never touched this board again. I waited around until i got a eprom burner and the correct eeproms.
Today I opened her up after burning my cps2 tester rom and after shorting the EXC5 rom. Everything works great! Happy days!
Ok i cried victory to soon. The game crashes after two rounds this get progressively worse. When it cools down the problem appears later.
So apparently something overheating. I checked all the chips when the board was without case but nothing seemedoverheated I could touch every chip with my bare hands.
I tried the Suicide tester rom but only got a pink screen. It never booted . I'm using AM27C4096. These are correct right?
Or can't I boot it with an Openkey installed? The onboard service menu said all chips are OK.
When I reinstalled ROM3 I booted without case and the game kept playing without issue for over half an hour. When i reinstalled the case same issue returned. A cracked solder joint in the connectors to blame?
I must say that the voltage meter on my super gun also only says 4,9 but all my other games play without issue.
Thanks for helping out!
Hello
Basic steps first :
Take time to clean the boards connectors using a good contact cleaner (
I’ve had several cases of strange symptoms because of this (purple screen, missing graphic elements, etc.) , by applying contact cleaner to each connector of each board, then connecting and disconnecting them several times.
If you’re modchip il correctly soldered, it will permit the board to boot. Second steps will be to take a photo, then carefully remove all the EEPROMs. Clean each EEPROM socket using contact cleaner and a toothbrush, and clean each EEPROM pin with sandpaper. Then, put them back in place.
For sure the board include self test at startup (eeprom..) so there is a minimal chance that your issue is not related to mask/eeprom content. : https://www.arcade-projects.com/threads/cps2-a-board-eep-rom-bad.8756/#post-470193
the « case issue » is related to contact issue (I’ve same issue in past), be sure (tripe check) the plastic case for anormal level that can impact the contact.
Double check visually alll golden pins in board connector and clean them using a brush and alcohol gently !
