daskrabs
Yes I can test next week. I'll let you know. Thanks again.
I'm going to test this tonight. Can you summarize the changes thus far so I can verify them? And to be clear, you want me to test "Conv3" and not "Conv4"?BTW: Only d72-12.bin and d72-13.bin are patched. No need to reburn any of the other roms in the archive for this update....
That would be amazing if it isn’t too much trouble.@mattpsu03
it's possible. There is no space for a new settings in service mode, but I could remove "BG.Music ON/OFF" and replace it with "Continue ON/OFF."
Thanks so much for this! Now, it is perfect!@mattpsu03
Here is the updated version of Puzzle Bobble with the "Continue: On/Off" option added. This archive contains only the updated files. The BPS patches that also include the "Quiz Sekai wa SHOW by shobai" conversion can be downloaded from archive.org
Thanks for the donation![]()
@Pythagoras@mattpsu03
Discovered a bug that prevented the High-Score entry to work if "Continue" was set to OFF. I have fixed the bug and updated the file and link above...
@PythagorasHmm... There is a bug in the original game. A check for VS mode (2 players) and it goes directly to the continue routine. This check make it impossible to get a high-score for any player and it also make my continue check to fail!
I will try to find a solution that fixes both problems...
