FS Some acrylic case ( brezzasoft, cps3 , stv , MVS , pgm , NAMCO system 10 /12 )
santashiva
France
Hi
For sale the following kit , prices excluding shipping fees, from France
each kit is supplied with its screws and spacers and feet
Kit For slot MB1B : 20€
Kit for MVS MV1S/FZ : 20€
Kit for STV :motherboard : 40€
Kit for CPS3 motherboard : 40€
kit for Gaelco GAE1 ( Thunder hoop. Biomechanical toys , squash …) : 40€ solid out
Kit plexi for brezzasoft slot : 20 €
Kit plexi for MV2F slot : 55 €
MV1FZ back for sale
@santashiva sold me a System 12 case and it came out very nice. Everything fits as it should and was easy to assemble:
Only bit of feedback I have is could consider adding some extra height clearance around the heatsink or maybe a set of air vents that Highflow included in their design. Here is a pic for reference, I have one of their cases attached to a different board:
Probably won't make much difference in performance but either way great job on this case and seller is very easy to deal with.
Thanks for your feedback, I will keep your judicious remark in mind for my next plates.
@santashiva since you are in France I will likely not buy one of your cases due to shipping, however if you don't mind a suggestion. It might be nicer if you cut a hole for the heatsink and move the plexiglass down some. You can make the heatsink stick out through the hole or even put it flush with the top of the plexiglass.
Great cases and thanks for making them!
Update
Pcb SNK ( kof 2003 , MS5 , SVC ) : 30€
Capcom ZN1 / ZN2 : 35€
NAMCO system 11 : 35€]
Taito Gnet : 40€
