3D printed adapter plate - BlueSCSI(v1) into standard CPS3 CDROM drive bracket
hatmoose
New Zealand
This one came up in conversation with a cool forum member the other day, fun and useful idea to model, thank you!
This is designed to drop into the existing CDROM bracket on some CPS3 setups
and will hold BlueSCSI V1 (or anything else with the same mounting holes).
STLs are in the attached "CPS3 bracket stock for bluescsi v1.stl.zip"
these slice and print fine in Cura on ender3 pro - so if those can print it, anything can :-)
You will need
2 x M2 x 5mm nuts+bolts to hold the bluescsi into the 3D bracket
4 x M3 x 6mm nuts+bolts to hold the 3D printed bracket into the CPS3 CDROM drive bracket
