maiden2099
Middletown NJ, USA
Hey Guys, I have a CF setup with a 4.02 DIMM and went to turn it on (To take pics to sell of course) and I'm getting Error 22. Cleaned the pins, reseated, swapped daughter boards and nothing. Regular cart works fine, tested voltage on Sun power and Capcom I/O power and all in spec. Any other ideas?
maiden2099
Middletown NJ, USA
Oh and a side note, its been in the cab and was working as of 2 days ago.
alexvw
Illinois
Hello am running into similar issue, I just did a fan replacement and got same set up with DIMM and just stopped working I get a black screen system don’t even boot but if I switch to a regular cart system works and game boots with no problem wondering if something failed inside DIMM cartridge so have no clue where to start
mR_CaESaR
Sydney, Australia
You may need to replace the buffer chip on the DIMM (it's directly on the oppose side of the BIOS).
I had this exact issue and thought it was the BIOS, I changed the BIOS so many times, but continued to get error 22. I changed over the buffer chip and upon first boot it worked perfectly fine.
This is the buffer chip
alexvw
Illinois
so for my problem i back track and found that i was running old multi bios ones i burnt a new bios in both mother boards everything started working again i let system run for hours in demo mode no problem
doccaz
Brazil
Running into this exact issue with my NetDimm as well. It was working fine for a week, then started getting error 22. Tried changing the power supply for an adjustable one to mitigate the low 5V line under load, but haven't thought about looking into this chip.
Is it normal for the DIMM to just turn itself off when this chip is bad? I can see the LEDs on the boards going off when it powers up. The Naomi itself works great without the DIMM, and all diagnostics pass.
Did you use a specific manufacturer? I'm looking at the datasheets, there are options from NXP, Hitachi, Renesas, TI.
mR_CaESaR
Sydney, Australia
I believe it's very common for these to go if the psu runs over 5v, it doesn't take much to kill these from what I've read.
I bought my buffers off ebay
XeD
Vancouver BC Canada
I just repair 2. If replacing the buffer doesn't fix it, the bios might have gone with it
doccaz
Brazil
Ok, I replaced the buffer chip, still no go. The chip on my finger is the original one, the replacement is the Philips part.
The NetDIMM BIOS chip would be the one labeled IC11 at the top of the daughterboard?
mR_CaESaR
Sydney, Australia
Are you 100% you've soldered correctly and there's no bridges?
Have you also done the bios?
Rukas
Brisbane, Queensland, Australia
One of my netdimms has this same issue. Must be crazy common.
mR_CaESaR
Sydney, Australia
It's when the voltage hits over 5v. The tolerance on the buffer chips aren't that great.
XeD
Vancouver BC Canada
The bios ic is located behind the buffer ic. Ic 36 for the 48pin and ic14 for the 56pin.
doccaz
Brazil
I got the 56-pin version. Unfortunately I do not seem to have an adapter for a 56-pin TSOP for my programmer :(
I guess I cannot use the other pins for a 48 TSOP without altering something else on the board, correct?
XeD
Vancouver BC Canada
