SOLD 4x Seimitsu LS-33 Kai joysticks
andynumbers
Atlanta, GA
UPDATE: ALL SOLD.
FS: 4x Seimitsu LS-33 Kai joysticks.
These were offered by Arcade Shock a few years ago and are no longer made. Very rare stick to find now. This is the fastener version, so you will need a 5-pin adapter harness if you plan to use in a cabinet that normally uses JLFs.
What's the deal with this stick? Essentially it's a LS-55 with a shorter shaft and a permanent shaft cover. Perfect for flush mounting to a panel.
Example: Egret II control panel normally has a special bracket for JLF sticks to lower them 5mm or so for the perfect shaft height. Now you can mount this stick flush and retain the same correct shaft height.
Another example: Use a Kowal universal joystick plate and install in a Neo Geo Big Red or any other American JAMMA cabinet with metal control panel.
Condition: Like new.
Asking price: $40 each. Would like to sell in sets of 2 or all 4.
Octagonal gates available at extra cost
Black balltops available on request, in case you plan on using a colored balltop.
