LittleLarrySellers
Brooklyn, NY
This is more of me just venting but man these damn A+B boards are SO sensitive!
I don't know if I am the only one who has this problem of sometimes you get those jailbars and a little squeeze of the shell will usually do the trick? It seems like if you ever move these around like I do since they are not installed in a dedicated cab so sometimes just from the shelf to the TV is enough to get the connections off. I move these things like I am carrying plastic explosives and still sometimes it happens.
I am working on a small mod to fit my HDMI kit into my metal CPS2 shell since I like how secure the boards are in there but then I can't do the squeeze/flex method to make the jailbars go away if it happens so it is driving me crazy :cursing:
LittleLarrySellers
Brooklyn, NY
I do use the metal clips but it's still usually requires a little squeeze. It's very fragile like Smokey.
I am redoing my setup and once it's entombed in the metal case I am not going to move this anymore. So I just need to get the connection good once then I'll never touch it again other than to change the games on the lcd.
