@caius @Darksoft and others have done some great repos taking the reverse engineering work by furrtek towards re-creation of Custom chips to help old failing board.
Sega System 32s are failing at a high rate due to bit-rot on the 315-5385 custom, this is a system controller/timer and really only used on the System 32.
When this starts to fail Audio in the game becomes scratchy, then it will degrade to completely silent audio and IC16 Checks BAD in memory test (even if the RAM at IC16 is completely good).
I believe more advanced failures cause graphics to start to degrade as well. https://caiusarcade.blogspot.com/2019/11/golden-axe-revenge-of-death-adder.html
Having spoken with Ken it sounds like the design of these chips cause them to become susceptible to moisture and they literally degrade from the inside out. So it's essentially a ticking timebomb for all System 32 board.
Personally, about 1/3rd of all System 32 boards that have passed through my hands have had this issue.
Currently the only solution is to pull this chip off of another System 32 board, which isn't great and only really kicks the can down the road.
I see furrtek already has this chip listed in his Reverse Engineering Github: https://github.com/furrtek/SiliconRE/tree/master/Sega/315-5385
not sure how far along it is to being reproduced in fabric, but I'd like to see if @caius @Darksoft or someone else would be interested in creating a repo for this chip.
I know I would buy at least 2 of them, I've seen a dozen or so posts on various forums with others experiencing the same issue and I'm sure Ken would be a regular customer as well.
