hatmoose
This one is a bit of a narrow use case. I wanted to make some reproduction CPS3 SIMMS.
Since all of the flash chips are coming from questionable chinese resellers I wanted to test the chips before I solder them on.
My Eprom programer is the cheapest money can buy - Xgecu T48. It does have an add-on TSOP48 NOR adapter (ADP_F48_EX-1) which will sorta-kinda read/test these chips. What it won't do is read/test the reverse pinout chips.
Several options present themselves, The least practical was to make an adapter board to modify the ADP_F48_EX-1 to match the pinout of the "Reverse" chips.
As you can see the adapter board (red) requires the total and permanent modification of a donor ADP_F48_EX-1 as well. I did consider recreating the ADP_F48_EX-1 but it has a weird unmarked chip on it, presumably to stop people doing exactly that.
Will it work? Let me test and find out
