alamone
This is an idea that I was thinking about, using something like LTC6904, which is an adjustable oscillator programmable from 1kHz to 68MHz. The idea is to hook this up to a microcontroller and then replace the existing crystal oscillator that is used to clock the main CPU on an arcade PCB, e.g. a 10MHz crystal for clocking a Motorola 68000. In this way, you could adjust the frequency from stock to whatever overclock you want easily, and by adding a 7 segment or OLED display to the microcontroller, you could easily see the current clock speed. Has anyone done something like this?
