freddiefiasco
Thank you thank you!you can boot up without that wire, it is indeed a jumper to help alleviate interference problems with multiple machines near each other.
but, if you're curious this is how they're jumped on my board:
One important thing to note is that the connector for the LED array is pinned backwards from all the connectors on the LED modules. So pay attention if you're building your own harness. or if you're using an original hardness make sure you're using the right section for that part.
Exactly what I needed!all my photos and info can be found here: Shooting Gallery: Sega Type-II IR on a 108" front projection setup.
