Anyone with a Top3000 programmer successfully burn a 48-TSOP flash chip?
RealMFnG
NorCal
I am trying to burn Naomi Dimm FW 3.17 and want to get to the Darksoft CPS3 Super Bios eventually. I bought some Micron chips. But the Top3000 doesn't have this manufacturer in the list of chips that it supports. If you have been able to burn this flash chip, let me know what chip you were able to use with the Top3000.
Sorry for bump, but did you figure this out?
I want to do basically the same thing.
Never worked with the Top3000. I have since picked up a different programmer.
I had this same problem. After a bit of research I found out that the TOP series of programmers doesn't play well with 48 pin TSOP chips (and some other 48 pin chips). I ended up making an adapter that shifts the pinout by 13 places, allowing you to program any previously unsupported chip. The adapter can be used to directly program any 48 pin TSOP on any TOP programmer, OR allow you to plug in your existing tsop48 adapter or 48 pin chip.
Writeup: https://blog.kenzycarey.com/2020/07/programming-48pin-chip-with-top.html
Store: https://www.lovegood.dev/2020/07/top-48tsopdip-adapter.html
eBay: https://www.ebay.com/itm/233638652572
I purchased ebay adapters for tsop48 to dip 48 and each time I loaded a 29400TA-12PTFN [I selected AM29F400T_(TSOP48)] as the chip type it would error out with this..
I then came across this post - like you after searching and searching..
https://www.mcumall.com/forum/topic.asp?TOPIC_ID=2604
This was the part that was of great interest
So I rigged my converter up to the way the post had, dip pin 1 goes to tsop48 pin 13 onwards.
When I tried to burn the flash, it would appear to have burnt it, but each time I tried verifying, it would error out. Needless to say, I still tried soldering the flash back on to the cart, but all I got was a suicided cart - it may have been my soldering job, but I went through it with a fine tooth comb and could not find any issue with my soldering.
I've now just purchased one of your adapters hoping to have my CPS3 bios woes sorted with this. I am assuming I can also burn naomi flash with this adapter?
Finally, when flashing 29F400 roms, is there a particular one you're choosing from the options? And are you just loading up Darksofts file and then "writing" no special options?
When successful it will verify without any problems.
If its supported by the Topall software then it should work.
Select the option that bst matches the text on your chip. In my case it was 29F400B TSOP48.
Lastly, if you still have problems, people have reported having best results with Topall version 8.25
Anyone have Topall ver. 8.25?
I've built this adapter and burned the flash verified and protected, but still got suicided cart with garbled screen.
I've only got 8.81 which is the version I used.
I've been successful with one cart but unsuccessful with another.
I posted this a few weeks ago in hope that I might find someone else having the same type of issue - but my issue might just be a user issue :) (I don't know... I'm still yet to send the stuff to xodaraP)
