stringbean
After much looking I recently managed to buy two arcade machines - an Astro City and a Blast City. I've been reading a ton of other peoples Astro City restoration threads (which there are a few here and other forums) trying to gather as much info as possible. I've never owned an arcade machine before so pretty much all of this is new. My plan is to document the process as I go and hopefully rely on some of the expertise here in this forum for answers that might help me as well as others down the road. The Astro City I bought is already in pretty decent condition albeit with some missing / incorrect wires. When I connected up the one CPS2 Street Fighter Zero board I just bought the game fired up and the volume was blazing loud. I currently have no idea how to activate free play or turn the volume down but that was a promising first step. Then, I opened up the control panel and saw there is a missing lock on the left. Also, the wiring going to the joysticks is something I'm a little unfamiliar with as I was hoping it would be compatible with a Sanwa JLF lever. The seller did not include a kick harness or correct control panel cabling for the kick buttons which I will need to find. I've already found some auctions on eBay for something that might work, but haven't pulled the trigger yet.
Based on what I've seen in some of the other Astro City restoration threads, I've bought the following items:
Here are some pictures of the arcade right now. I'll continually post as I make progress on the restoration.
- Simple Green cleaning spray
- Magic eraser sponge
- 52mm "Green Gel" skateboard wheels & bearings to replace the stock arcade wheels
- Meguiar's M4916 Marine/RV Heavy Duty Oxidation Remover (specifically for removing stains/dirt from fiberglass)
- Novus 7100 Plastic Polish Kit (for the control panel & black facia cover)
- Chemical Guys Heavy Metal Polish (for the metal kick panel)
- Impact drill bit set (I've seen impact drills necessary to disassemble parts of the arcade frame)
- HONE Car Buffer Orbital Polisher
- Replacement reproduction 2 player Astro City control panel
- Set of Sega 5380 locks/keys
- Set of Logitech z-5500 speakers (others have mentioned these are a straight drop in replacement for the original speakers)
- Two new Sanwa JLF levers and all new Sanwa buttons
- NOS coin slot
- Kick harness
- Kick button control panel loom wiring
- 3 rolls 1/2" wide 1/8" thick foam
- Fluorescent light fixture (This one)
- Ratchet set for bolts
- Black extension cable (To upgrade power cable to be grounded)
- New control panel chrome bolts
- 3m rubbing compound (to remove scratches from monitor screen)
- Hand cleaner with pumice (to remove scratches from monitor screen)
- FG-1E Ballast Starter
- Hand file to reduce width of skateboard wheels
- RAL9002 paint pen
- Candy White Audi LB9A paint pen
