WTB Astro psu plate with wiring to psu
Want To Buy
Kidkaos
Northern California
Not sure if I'm calling it the correct term but I am in need of 1 psu plate for the Astro. Mine is missing and Yaton is still not responding so I'm looking elsewhere. Let me know if you have any leads on one or even a solution to get my shell going.
What I'm looking for is the wiring plate that goes from the ac line to the small fuse box that wires to the inside of the cab through the psu (see pictures)
Thank you.
Are you just looking for the plate? Or the wiring to go along with it as well? If it’s only the plate it could be 3D printed.
Im sure you can put that together quickly yourself if you can't find it
Power cord socket - Qualtek 703W-00/04
Filter - Tokin (Kemet) GT215J
3 Amp Circuit Breaker - A TE W58-XC4C12A-3 should work
Rocker Switch - A Wurth 471005264152 maybe, there are tons you could use
Then just have someone fab a quick metal plate for you, the wiring should be pretty easy. You could do it yourself with a dremmel and some flat stock aluminum or stainless steel :D
