Atomiswave Sd Speaker Upgrade
Zitz
Melbourne
Hey everyone did a speaker upgrade to my atomiswave sd during the week and boy oh boy does it sound much better what i did was
Took out the old speakers kept the steel bracket and from there bent some
Sheet metal in place for the new speakers i used logitech z213 for their size they fit perfectly flush where the mount goes
Screwed the sheet metal plate to the bracket then hot glued the speaker to the sheet metal plate i then surrounded the speaker mount hole with foam tape to stop vibration I then screwed in the new modified speaker mount and covered the area with black tape to stop the light bleeding through
Double sided foam taped the mini sub inside the machine and mounted the volume
Control inside the control panel
For a $35 mod this has honestly stepped up my enjoyment 10 fold
Has anyone else done a atomiswave speaker upgrade?
https://imgur.com/a/vFgYQhT?desktop=1
Hmm...true. Might get a set to try them out. Or in the end just build custom enclosure.
Something to add make sure to buy a 3.5mm extension about 1.5m will be fine , i say this as the speaker cord is rather short
