Atomiswave sound issue
aha2940
Colombia
Hi
I got two AW boards and a boot MS6 cart. Both boards play fine, but the sound is weird, like the music sounds strong, but some sound fx sound at a very low volume. This happens with both boards, so I don't think there's an issue with them. Also, I play using a supergun, but this SG is also used with CPS2, CPS1, PGM and Neo boards, all sound fine. Any advice on this? maybe the crappy MS6 boot is failing?
Thanks!!
since it is consistent across 2 dif boards and your supergub works fine with everything else does make me think its the bootleg cart. I havent played around with my atomiswave for awhile but seems like there should be a sound test option in the service mode. Ill try to remember to check tonight
Thanks, Coyo5050, I thought the same as you. I'll check the sound test and see if I can see anything wrong in it. Unfortunately, MS6 original carts seem to be out of my reach for now due to their price, I guess teh boot will have to be used for some time.
Thanks!
