FS Audiophile with psio mod switch installed and colour mod also installed
Zitz
Melbourne
Got a audiophile psx with psio and switch been installed also colour chip installed so will now play pal or ntsc in native speed with correct colours $500 aud post paid at buys expense located in Melbourne
What is an audiophile PSX?
The 1000 series PSX's had RCA jacks for their audio out. Some articles way back claimed they were the best CD player you could buy under $500 or something, so they started being called "audiophile" PSX's.
Correct I probably should have mentioned the sound dac on this model is the best
Yes but the OD is the worst (doesn't really matter if you go the ODE route), I think I saw people swapping one from a 9001 model, of course you end up with a Frankestein machine but it's not really noticeable and is truly the best model you could assemble.
Also the 5001 has the same DAC than the 1001 with a better drive.
[EDIT]
Found more info
Darius Saturn said:
la 7502 est la meilleure PS1 "normale" car elle a les perfectionnements qui lissent les degradés et brouillards par exemple ,
+ elle affiche en couleurs les jeux imports MEME avec un cable composite !
et tout en gardant le port paralelle au cas ou !
la 1002 est "speciale" avec un tres bon proccesseur audio et des sorties audio direct soudées sur la carte mére !
mais il faut lui mettre une alim de serie 5000 ou 7000 car celle d'origine est un vrai grille pain
et changer son bloc optique de mer2 par un de PSone qui va parfaitement et est tres efficace pour lire toutes les marques de CD-R !
It seems the best "FAT" PS1 is the 7502 with better video hardware (integrated anti-aliasing & defog).
And it displays games from other regions in colour even with a composite cable.
The 1002 can be perfected by installing a PSone drive and replacing the PSU with one from a 5000 or 7000 series (the OG one overheats).
