Axunworks JAMMA Power Switch
drfunk2k
From USA / Nanjing, China
If you frequently replace your arcade game board, it will be very convenient to use the JAMMA switch board. You only need to turn off the JAMMA power supply instead of turning off the entire arcade machine. This reduces the failure rate of CRT and scanning boards.
Sales Page: ($25.00 usd)
http://www.axunworks.com/JAMMA-power-switch-p497559.html
all available on aliexpress too (with identical photos) ! and other items from axunworks (which appears to be a more arousing western-facing portal)
im going to buy one. its basically the same price as aliexpress shop ( www.aliexpress.com/store/607318 ) but if I buy it from axunworks they apparently will use DHL....
hmmmmm
i have zero problems with the western store front, or the aliexpress option. cool item.
edit: read below replies
Axunworkshop does not sell on Aliexpress, these are resellers. Also, if you buy from http://www.axunworks.com/ you can get support from the forum and returns if there is a problem.
Axunworkshop DOES not offer support or returns from aliexpress. This is not him these are resellers.
Just remember if you buy from Aliexpress we do not offer returns or support, you will need to get this from that seller
