Batsugun help needed!
Hammy
MOVED = DON'T SEND ANYTHING
Hey anyone got a batsugun lying around? Got one in recently with N00b damage on the processor and ram.
Got it mostly figured out but seem to be missing a connection to pin 19 of the 68000.
If someone with one can check this pin it would be nice to get this one done :)
Thanks!
I am not convinced that it is connected anywhere. Probed for a while. Looked at the pin under a zoom. I don’t think this is 3 layer...
it’s an output according to a pinout I see, VMA active when low, and looks like it remains high on my scope.
Just seen this on YT, hope u get it fixed. I have the original PCB if you need anything cheers.
Meant to say, I can lend you the original PCB if that would help
Excellent, never doubted you for a second!
The "untested" GAL was where the doubts were! If that was bad it could be sat forever in the jank room waiting for a good dump.
Gal looks to me as tested good :) (can't see it causing a sound problem)
Also it's running ATM with the wrong CPU (12mhz vs 16mhz) it could be a timing problem on the sound.
