Hello,
I have a simple question that has been bothering me. Right now everything is wired for Jamma in my cab but I want to add a brooks universal fighting board to connect a ps4 (or pc eventually).
What is the best way to do so ? The quick and dirty way would be to connect 2 wires from the buttons/stick to the brooks adapter but it means if the JAMMA is powered at the same time it will receive inputs and I'm not even sure about the other electrical side effects
I was thinking maybe use an old printer connector (db 25) and wire the buttons/stick and connect to a db25 "switch" ( https://www.amazon.com/C2G-Cables-4-Port-Manual-Switch/dp/B0000512C5#customerReviews) and select which system receives the input.
So I'm here to avoid making mistakes and get instant wisdom from someone who already did that
Is there a magical board with quick connect for sticks/buttons that would solve this problem ?
Thanks !
Thanks !
