FS Blast City Speaker, OR1,2 , ID1,2,3, F355
winterflame
France
Hello,
I offer for sale speakers for Sega Blast City, Out Run 1 & 2, Initial D 1 - 2 & 3, F355. These are not original speakers, but replacements. After several months of research and various tests on different HP, I was able to find my happiness! They are professional speakers of a brand that is not sold to the general public and you have to be affiliated to this brand to buy them and I could have them thanks to my company.
Technical information:
To better understand the following, you should know that the original HP of the Blast City are "Toptone F17E4U01-1" whose details can be found here : http://www.toptone.co.jp/en/products/full/F17E4U01-1.html
Impedance 4 Ω
Rated Input 6 W
Resonance Frequency 125 Hz
Frequency Range Fo~20,000 Hz
Output SPL 81 dB W/m
And Sega, in its amp put the LM1867TF amp chip whose datasheet is available here: https://pdf1.alldatasheet.com/datasheet-pdf/view/8683/NSC/LM1876TF.html
The speakers I propose have a similar specificity, however they are less powerful in "W" which will allow not to pull on this AMP chip which for the most part, has already been well used! Therefore, the sound pot turned to half of the blast will output on average 85 DB!
Rated power 2 W
Maximum power 4 W
Impedance 4 Ω
Resonant frequency 420 Hz
Frequency response (-10 dB) 220-20000 Hz
Mean sound pressure level 81 dB (1 W/1 m)
I propose to provide you with the 3D support that I modeled and its screws (you will receive them already assembled, they will just be placed in the speaker in place of the old ones).
I sell the speakers 20€ each fdpout, for a complete Blast City that's 4 * 20 = 80€.
Here are some pictures:
I have recorded 2 videos to give you another idea (attention it was filmed with a phone):
For the shipping costs, I would ask you to notify me by Mp mandatory your address, information
OPTIONAL, but strongly advised:
I can provide you 2 replacement capacitors special Audio for 4€ extra.
Original capacitor : 2.2uf 50V bi-polar / New capacitors 2.2Uf 100V bi-polar special audio
It is advised for a better sound performance to capkit the sound amp of your terminal!
I also advise you not to damage the HP to push the sound to more than half simply, because they support less watts than the original ones, in any case at half, it will be already too strong ;)
Editing tutorial:
To start, take the speakers out of the terminal, to do this you will need to take the tube out.
Then unscrew the screws (the screws are all the same on these speakers, speaker + cover) :
Open the "cover", be careful you may have trouble opening it, because it is slightly stuck inside:
The queues are connected like this:
Disconnect them, beware some connectors can be "hard" feel free to wiggle from right to left.
Use a scalpel or a cutter to cut out the foam that holds the speakers in place. Be careful to cut horizontally and vertically:
Then unscrew the speakers:
Remove the speaker, be careful the "shield" can bother you when leaving, do not hesitate to slightly forced:
OPTIONAL, but recommended (if you take the capacitors) :
This capacitor filters the bass on the tweeter and improves the audio flow.
Peel it off, and remove as much glue as possible from the solder joints:
Removed it, little trick added from the new extinct to remove it more easily:
Solder the new one like this:
Add hot glue to prevent the capacitor from vibrating:
Place the speakers and screw them with the same screws as the original one, don't hesitate to press lightly if it is not glued to the support:
It must be straight:
Then, fix the red connector at the bottom, you can't go wrong, the plugs are not the same size for the + and -, push them all the way in, you can almost hear a "clip":
Do the same for the other 2 connectors, same, you can't go wrong:
Then close the cover, screw it on and put it back into the terminal.
FAQ :
[Do the speakers distort the image?
- No, the speakers are shielded.
[Do I have to mount the speaker?
- The speaker arrives at your home already mounted, it will be necessary to place them & screwed in place of the old speaker and of course to connect them ;)
[How long should I wait?
- First of all, I do not put anyone in "production" if I have not received the deposit, then the production can take 2 weeks. Why? Because I'm the only one working on it, I'm dependent on the professional supplier I work with and the 3D printing is only done when I'm at home (and anything can happen with my 3D printing :D). Therefore, patience is the mother of virtue!
[How do I install the speakers?
- The tuto is a little higher ;)
[I don't feel like "Capkit" the sound card of my terminal and the speakers, how can I do?
- I can take care of it if necessary.
[For what terminal are the speakers compatible?
- The speakers are compatible for the arcade cabinet :
Out Run 1, 2 - Initial D 1/2/3 - F355 - Blast City
If you are interested, please send me a PM. Following this PM I will ask you for information and depending on the number of speakers you want and the destination the shipping costs will be communicated to you. If you want you can make a pre-order of 10€ per speaker.
Name / nickname will be added next and this post will be updated via this message, red = awaiting payment / purple = in production / green = shipped / striped = received
Reservation:
