GeekMan1222
Note: This really only pretains to Classic Collection Volume 1 boards.
I am noticing something that I have not seen documented anywhere about the ND-1 ND1 system boards.
I am also not sure if it relates to this odd video distortion issue im having when game volume is turned up to 25 or 50 + % due to what I assume is bad decoupling or power management with the RGB Amplifier. Basically the power amp is kicking noise or pulling power from the video amp ill get dark vertical lines with boomy bassy volume and if you turn the volume up to like 75-100% on the board then its so bad that the video output begins to lose color information too.
Anyways I thought I could be interesting to at least document this. If anything I could maybe reverse engineer the fix they made on the Namco Vol2 board and make a custom mod board to try to do the same mod board on the Classics Vol1 board (seen below)
ANYWAYS
What I need help with.
- If your board has a bodged on capacitor (attached to the LM1203, see photos below).
Can I get the values from this capacitor?? ( I am thinking this was a field service fix namco gave operators if they called them saying they found something wrong or they did the fix when sent in.)
- If your board has a mod board thats sitting above the Video Amp IC. I would like to document this board so I can repro it potentially. (im just assuming this board to be rare as eff because I only seen one picture of it on the internet, probably a late life board factory fix before they finished the revised board for classics vol 2. )
Heres the nitty gritty:
If I check the power pins on this LM1203 video amp theres a significant loss in voltage on the rail anywhere from like 3 to 5 volts if i am remembering correctly when the volume becomes bassy/boomy at medium to high volume.
I tried adding my own capcitor to this chip the same way. 100 uf cap seems to make SOME difference but its not a ton and once you push the volume past about 50% the distortions are back again.
I also added a 470 uf cap in parallel trying to just SEE if I can have any kinda of improvements. Its not really the proper engineering way to go about that but I figured why not give it a little shot.
So I noticed early on when I was repairing my Namco Classics 1 that Classics 2 has some differences with the power rail or w/e leading into the RGB video amplifier chip they use. The Classics Volume 1 just has a simple diode and a 47 uf cap to decouple or filter the video amp from the rest of the board. The Classics Volume 2 has a bunch of other stuff added like a inductor a IC (I havent looked up what exactly it is yet) and some extra capacitors.
Im wondering if Namco just really messed up when they first designed these boards and theres power delivery problems with that video amp or its easily susceptible to picking up noise of the power rails. Clearly something was wrong enough for them to make a mod board and then totally revise that portion of the board later.
I have noticed that some boards have a capacitor added to the RGB amplifier bodged on (its installed and positioned the same way on multiple boards I find on the internet IF they have them at all theres not many. Then I found one particular board that has a custom made mod board with Namco silk screening and plastic clip stand offs adding every component that the later revision board uses for its RGB amp for say Namco Classics Collection Vol 2.
The majority of Classics Volume 1 PCB's I see on the internet including mine.
Bodged on Capacitor of which I have ZERO idea what its value is...
With the offical mod board attached to the PCB. (this board closely matches the additional parts added to the next revision of the board (Example Classics Collection Volume 2)
The next revised version of the board. (Classics Vol. 2) See the design is now miniturized and added into the actual board now\
ANYWAYS
