Capcom I/O?
BNGamesReviews
Not here anymore.
Hi Everyone,
Just grabbed my first 256. I read somewhere, though there were no real details, that I might be able to use the capcom I/O board with the 256 instead of the 246 kit PCB it came with? Is this possible and if so what are the limitations? (Im sure there are some). Id prefer to use it since the Kick Harness is already wired in on it.
I plan on using this mostly for Gundam vs Gundam and Soul Calibur 2 (Still need to find a copy of SC2)
Thanks!
New issue, I got it unboxed and plugged into the Cab with the I/O it came with to test and im running into this. I think I have a bad drive?
Have you adjusted the power supply? Or you can change the dvdrom drive if you have a spare system 246/256 to get to know the problem
