Code One Dispatch: what to do when your steering pulls left
awbacon1
Chicago
I don’t mean the wheel is actually moving left, I mean when you have everything wired up correctly…the IO test menu is perfect…and in game the analog values are all pegged hard left.
It’s a motor power setting issue. If you don’t have a resistance motor / it’s malfunctioning / you are playing outside a cabinet…any setting in game settings that is NOT the green colored “normal” setting will cause the steering to not function. Don’t ask me why. You’d think off would also work…but nope!
Also if you change the settings THEN go to game mode…steering pulls hard left.
Only by setting normal, saving the setting, entering the game, powering off THEN back on will get steering functioning as expected.
Don’t bother with Dip 2 that bypasses the steering checks either…that caused all analog inputs on my setup to not function.
Took me two hours yesterday to solve that problem. Leaving this here so when the next person encounters it they won’t have to draw a flow chart of every variable till they figure it out 😂
