FS Coin Reject Credit Button Kits - Added Aero Table Kit
FrancoB
UK
Coin Reject Credit Button Kits - For various cabinets. Vewlix example below. See further down the post for other cabinets
View: https://youtube.com/shorts/HUzZV7lNRdw
Allows you to use the coin reject button to add credits. The terminals piggy back onto the OG levered microswitch so you can still use coins/tokens too.
All of the kits have adjustment built in so you can fit the microswitch in the optimum position. It should be fitted so that the microswitch is actuated right at the end of the reject button travel.
The kit consists of a 3D printed mount, a fitted microswitch, wiring loom including piggy back connectors, a self adhesive aluminum cable clip and a couple of cable ties for additional cable management. If any additional nuts/bolts etc are required then these are also included.
The kits are easy to fit but there is a URL printed on the label that will take to a fitting guide for each version (currently WIP)
The price of each kit is currently £15 except the NNC and which is £16 and the Naomi Uni is £18.
Shipping Costs
The current shipping costs below are for any amount of kits. I imagine untracked shipping will be fine, I've sent hundreds of packages untracked with 0 issues. The tracked options are quoted if you do want them though.
UK
1st Class - £2.20
2nd Class - £1.80
(add £1 to either for signed for)
Europe
Standard Airmail - £3.45
Tracked/Signed - £8.95
Anywhere other than UK/Europe
Standard Airmail - £4.40
Tracked/Signed - £9.90
Check the spoilers below for pictures of the kits:
Taito
*Egret 2/3
*Vewlix
Sega
*Aero City
*Blast City
*Astro City/Astro City 2/New Astro City
*New Net City
*PRas3
Atomiswave
*AWSD
Konami
*Windy / II
Capcom
*Cute
Asahi Seiko AD-81P & AD 81P2
Fits a range of cabinets with one of these coin mechs installed.
Asahi Seiko 720-A
Other cabs TBC...
Thanks all for the interest.
The example above was made using some parts I had lying around. I've ordered some more parts to make them a little cleaner ^^ There is about a week lead time on some of the parts so expect some to be available around that time.
I've started an interest list in the OP and I've also added shipping costs too.
Once made I'll shoot out some PMs to those in the interest list to see if you still want them.
Will shout as interested but will wait till Egret and Astros are working as well to possibly lump order.
Good work here @FrancoB, a very creative and easy solution.
Cheers all.
It looks like E2 (and 3/AWSD I would imagine), NAC (+ AC?) & Windy 1/2 are going to be possible after receiving some photos/info.
It seems like the Blast could be a sensible candidate too, I'll try and work on that also.
Ive added you all to a new table in the OP.
@bagheera369, with the new info in mind, let me know what you're after and I'll get you added.
