SOLD Consolized CPS2 with RGB out
ZoomBoy
Oshawa
Hi all, selling my Consolized CPS2 A-board with RGB out via DIN, as well as two DB15 connectors on front with kick harness integration. Really nice consolization here, with adjustable pots for R/G/B and fan speed. Includes A/C adapter for both North America and UK.
Asking $500 CAD shipped. Happy to answer any questions, please take a look at the video below for more info:
Curious - Is this only usable with CRT's since it's an RGB out mod?
If the RGB out is pure/unaltered you would need resistors and caps to knock it down to SCART appropriate levels first...
But then you could run it thru any SCART accepting device, such as SCART-2-Component adapter, xRGB mini scaler and OSSC scaler.
This is all a supergun is doing, lowering the RGB values to SCART level and outputting.
If the RGB out is pure/unaltered you would need resistors and caps to knock it down to SCART appropriate levels first...But then you could run it thru any SCART accepting device, such as SCART-2-Component adapter, xRGB mini scaler and OSSC scaler.
Yup, thank you for that answer. All this is - is basically a cool supergun with kick harness integrated into the board. Same as using a HAS and connecting to an unmodified CPS2 board, except less cables to worry about here.
Hi, as Jassin said - if you run this through a SCART accepting device you can play it on an LCD, etc. Don't need a PVM/BVM for this.
The gentleman I commissioned the build from plays his personal one on an LCD at home.
