Anselmo
Bakersfield, Ca
I'm hoping someone can point me in the right direction as to which specific resistor array package to buy to replace these badly rusted ones on this A board. I've seen people call them resistor network SIP, or Resistor Arrays, and other technical stuff I'm not familiar with. I'd like to try to save this A board from becoming a parts board, and the rest of it has no corrosion just these sections here. Anyhoo, what are these called exactly and where can I get an exact replacement? Thanks in advance for any help!
Anselmo
Bakersfield, Ca
Thanks @Thrillhouse - that looks right. Hopefully somebody else can chime in before I buy a few of those.
Anselmo
Bakersfield, Ca
They ended up sending me 10 pin arrays instead of 9 pin. Can I use these and cut the last leg? Or should I exchange them?
Thanks in advance!
Mitsurugi-w
Arcade Admini-Moderator
New Bern, NC USA
Yeah when you order those, for example, a 10Kx9 will be 10 pins because one pin is ground. The 9 represents the number of pins for resistors.
I dont know about cuttind the last one off but you can cut the last pin off at least. Just make sure pin one lines up correctly.
