SEGASHIRO
Just a quick question to those who own multiple CPS2 boards from different regions - Is it easy to swap a one CPS2 board into an another region's case?
For example, if I have both a USA/Japan A board and B Board with a broken case, could I pull the pcb boards out and put them into an Asia A/B combo and have all the contacts still come flush together?
Or if I just swapped the A board in the grey region case to a US/JP one would it still mate properly with a USA/JP B board?
Basically, is the plastic casing different between the different region boards? I know the pins are different on the pcbs but were the CPS2 cases all similar enough to allow you to shuffle the cases?
Also...anyone know where to get cps2 A board case?
