CPS2 died in action
CoinFeeder
Sydney, Australia
Basically a copy of my post at the aussiearcade.com forums, but hoping that somebody here might have another idea before I get my hands on a new, grey A board:
I recently acquired a used CPS A+B combo with Xmen vs. SF. I worked great for a couple of hours but then crashed (garbled video output) on Day 2 while playing. When I turned on the arcade the next day I was greeted (quite literally as you may notice
) by some garbled output on the screen.
From what I read this will likely NOT a suicide situation, as the board doesn't show a solid coloured screen but garbled gfx output.
I gave the the edge connector (using a pencil eraser), as well as both boards a good clean again. I also reseated them one more time. No luck =( As I already tried the setup on another cabinet (where it used to work as well), it doesn't seem that +5V is the issue.
While I haven't received another A board yet, I checked the actual voltage coming from the PSU it was connected to when it suddenly stopped failing on Day 2. It was 5.4V and 12.1V... So maybe that was a little bit too much? I should have checked that when I received the arcade a few weeks back. Lesson learned... :# I now corrected the voltage to be 5.1V and 12.1V..
All measurements were done while another board was connected (RPi3 + RaspberryJAMMA) and running a game... So yeah, during load
Any suggestions how to fix this myself are welcome. Otherwise it would be awesome to know if there's somebody that has a great track-record on troubleshooting and fixing CPS2 boards. I'm located in Sydney but would certainly pay for the repair incl. shipping both ways.
Cheers,
mtn
5.4V measured at the PSU side shouldn't hurt anything, since it would read lower on the jamma edge (CPS2 draws a lot of juice). 5.1v would be a little low on my PSU if I wanted the CPS2 to have 5.0v exactly. That said, it doesn't sound like a voltage issue.
Yeh believe or not. I have to run my cps2 psu at 5.7v and 12.8v because I have other devices drawing off of it. So it sounds like you have what you need for power. Especially considering you are getting a garbled screen. I'm curious, some times when I owned a cps3 it would show a garbled screen so I would increase my voltage slightly and it would work.
May I ask what it is plugged into? Cab? Supergun? Are you using USB Undamn?
Overall, it may have just took a crap on you. Have you check the battery's voltage level?
