penrhos
I sold a CPS3 setup on eBay and it was thoroughly tested before I posted it out - I loaded all games from CD and played a couple of goes on each one (so about 6 hours on soak-test). Boxed it up in an anti-static bag and plenty of pink bubble-wrap.
Buyer received it, left positive feedback and it was fine for 48 hours then I got a "Item not as described" refund requested from eBay out of the blue...
On pressing him for more information than "It doesn't work" it appears he tried flashing "Red Earth" and it failed, then he said he got CD-Rom not ready (which I'd warned him about as drive is a bit slow to spin-up and to wait a few seconds for it to clear) but he power-cycled the PCB a couple of times instead. Now he's getting repeated error 13/23/33 and it won't write any games.
I had him return the PCB (even though I think he's damaged it) and of course eBay insist I pay return postage, even though he'd left positive feedback and admitted he'd been re-seating the simms.
It arrived last night and I'm pretty sure its the same simms as I sent it out with but not 100% sure he hasn't swapped any over.
The error messages 13/23/33 point to simm #3 being at fault so I took it out and put it in the spare slot in my CPS3 setup:-
So I decided to take all the simms out of the PCB and perform the same tests on them:
But the intel/sharp simm was in slot #4 not #3?
Re-filled the PCB with known good simms and it now works fine. So put on soak-test for a few hours and re-programmed it with no issues at all.
I can't prove that he's swapped any simms or he's damaged them so I've had to issue a refund.
Anyone come across these intel/sharp 128Mb simms and are they any less reliable to the Fujitsu ones?
- erased OK,
- write test OK,
- checksum OK,
- I can program it with any file from the CD calculate checksum, reprogram it and the checksums match,
- put it back into the original pcb and "Error 13".
- 2 * 64Mb Fujitsu simms- OK,
- 3 * 128Mb Fujitsu simms - OK,
- 1 * 128Mb Intel/Sharp simm - erases OK, programs OK but write test fails.
