KGtheLegend
Philly
Hi All,
Recently acquired a working CPS3 pcb with a third strike cart and cd. I;ve booted it up and it is working, however I noticed the version installed is 990608 which I understand is revised to remove unblockables and other things.
Is it possible to re-flash the 990512 version of the game? What would I need to do so? I have both a SCSI drive and the SCSI2SD board, although it hasn't been set up yet.
Thanks in advance!
KG
Mitsurugi-w
Arcade Admini-Moderator
New Bern, NC USA
This is original still and not a Darksoft cart, correct?
If so you just need to download the CD image for the revision you want.
KGtheLegend
Philly
Yes its an original cart. I am new to manipulating CD images so I'm not sure what the image is supposed to look like. I found a file on coolrom.com, but its a zip file that just extracts to a folder. Is this what i need?
If using the no cd, I just move this folder to the micro SD?
Thanks,
KG
SBZack
Hope Mills NC
How did you burn it? I just tried to burn the ISO to disk. My system is working with the new version perfectly but im getting "insert correct disk" error.
Thanks,
Zack
SBZack
Hope Mills NC
its working with the newer version which I dont want*** I just reread and it was unclear.
jassin000
Multi Boyz Sheriff
Multi Boyz
Nashua, NH
Burn to a CD or image to a SD card. Don't just move to the root of the drive.
Just expanding on this for @SBZack or anyone else having issues with discs/disc images.
PCs
  • Burning CD-Rs: Use Imgburn software (free)
  • Imaging SDs: Use HDD Raw Copy portable (portable version installs nothing so it is recommended over full setup, also free)
Apples
  • IDK use a PC? ;)
SBZack
Hope Mills NC
Ah I was using a DVD-R. This makes alot of sense
