Dariusburst game/monitor resolution
jugu
San Jose, CA
I have 2 questions which I am unable to find the answers to via various Bing searches:
What resolution does Dariusburst run at in the arcade?
What’s the native resolution of the monitor’s found in the arcade cabinet?
I appreciate the help.
Thank you.
I am not 100% sure on this but on the DariusBurst that I have (TTX2, original game and key) the resolution seems to be 720p when the game boots.. as for the original monitors I would guess that they are 720p and on Windows go a bit higher but not 1080p. I recall reading something like that..
The game supports multi Res monitors, but the internal Res of the game should be set to 1280x720 per screen.
Thank you.
Did you win that auction on yaj? The one for the x2 unit alone or the one with all the gear/wiring?
Thank you for the replies.
@Derick2k , I didn’t win either. Went out of my price range. But I’m in talks with a guy in the UK for the monitors, I was hoping they would be an improvement over the screen in a Vewlix F or L.
The screens on the darius cab are not the same as in the vewlix's. You would have to do some surgery to get them to fit.
I have a pair of the ones in the Darius cab, was thinking of using them to do a Dariusburst setup at some point.
I would steer clear of any Dariusburst if you're just wanting the screens. The screens aren't sealed well and there's a large fan between the two that blows dust inside them. I have pulled apart the casings to try to clean mine and the dust is between the LCD panel and the back light. I'm pretty sure it's a common issue with these cabs.
