ShllShockArcade
Hey guys looks like the BOM for Franks minigun is broken for the digital voltmeters on Digi-Key = all showing obsolete now. Anybody know of a replacement that fits the dimensions for the 3D print?
Was looking for blue or green but that will do. Thank you very much Todo, much appreciatedhttps://www.digikey.com/en/products/detail/seeed-technology-co-ltd/114990164/5487639
this red one should work.
Get an assortmentWas looking for blue or green but that will do. Thank you very much Todo, much appreciated![]()
Oh sweet!!!! Thank you!!Get an assortment
5pcs Two-Wire 0.28"LED Digital Display Voltage Tester DC Meter Voltmeter DC2.5V~30V with Reverse Connection Protection red White Yellow Green Blue https://a.co/d/3dSyDRg
No worries, I use them on a lot of projectsOh sweet!!!! Thank you!!![]()
Will do, thanks SkateNo worries, I use them on a lot of projects
Just be sure to calibrate them to a real voltmeter after installation, i.e. measure the points it's hooked to with a nice meter, and use the Potentiometer on the back of the module to adjust it to match.
