TylerDurden67
I see a lot of people asking what kind of neon and marquee for use or find the famous starter at tourist prices.
Let's be clear, we now live in a period where simple alternatives can be found.I had already advised friends to use LED, it consumes nothing, no need another starter and tinkers
So, I thought to do a dynamic marquee
Here are the results in the dark
with another light source
the videos done with my phone does not give the final result, which remains very good (even if my friend spectroman will say it's like gay pride )
Technical note:I use Ledstrip WS2812B, each LED is adressable.Can be found on different length with different numbers of LED per meter (excluding IP headband if you want to use in indoor or outdoor)Its powered using an 5V supply and with a data wire on which is injected color variations, intensity, etc ..I use this type of Ledstrip for a parallel project.All controlled by an Arduino.
Here,its just powered using an USB cable,numbers of leds are 60(not all displayed on the marquee) for not burning my USB port
Finally, it want me to go further, and make ambilight for cab
