NFGx
Through sheer ham-handed clumsiness I snapped one of the cables off the JAMMA adaptor cable for my Cyber Lead. Luckily all the pins are installed, and five aren't used. They can easily be removed and re-used.
Simply press the central tongue with a tiny screwdriver or whatever, and push it out of the connector. Then slide it back in where you need it to go, and re-solder that wire.
I can snap four more connectors before this becomes a problem. ^__^
This same fix can be applied to any JAMMA device using this Hirose connector.
Shown below: the empty slot where one pin was removed, and the broken pin near the new home for the moved pin.
