EZ Mod Hori RAP VLX w/Brook Universal Fighting Board Kit Compatible VLX Premium Xbox360
chacal231077
France
Hi :) I would like to know if this stuff and compatible version VLX Premium Xbox 360? ?( Thanks ^^
I wont be a drop in replacement into that arcade stick meaning you cant just remove the pcb that is already inside that stick and replace it with the brookfight board. U can still use it that arcade stick. You can rewire the buttons and stick to the screwdown terminals on the brookfight board. You would also have to make a hole on the back of the stick to accommodate the neutrik plug which is this https://arcadeshock.com/products/ne...panel-mount-with-d-shape-silver-metal-housing
I have a PS360 + installed in by Mr AZ of the forum Neo Arcadia at the time. ^^
The cables are with the PCB or they are sold separately ?
Sorry i did not reply. Yes all cables are sold separately for the brookfight board. Though its only a RJ45 to USB-A since all the new consoles use usb.
If you add the brookretro board to the brookfight board you can use the same arcade stick to play games from different older console from NES all the way up to Gamecube generation. Also consoles from Sega and Sony.
