Fantasy Zone (System 16A) - encryption key for 317-0016 ?
VectorGlow
Using Arcadehacker's file and an Arduino I'd like to re-program an FD1089B module with the key for 317-0016 (I've re-programmed FD1094's before).
However, the Arduino file for reprogramming the CPU module doesn't have the key for 317-0016 - does anyone know if this is available so that I could add it to the Arduino file?
0016 is not dumped - is that what you have or are you converting??
Sorry I should have said - yes, converting (but converting BACK to Fantasy Zone - this is a boardset that had been converted to a Time Scanner some time in the past as it still has the original Sega label for Fantasy Zone). I have a couple of spare FD1089B's and had hoped to use one.
Didn't realise that 0016 hadn't been dumped as I assumed they all had been.
Ah well, will have to use unprotected Rev A and a 68000.
Thanks for the info.
