Faulty cps3 cartridge?
Aleiex
Mexico
hi, I need some help with this screen, I can't tell if it's the pcb or faulty 2nd impact cartridge. Any help?
https://imgur.com/gallery/ih37d5v
ih37d5v
Can't say for sure based on one image... But what I can tell you is my CPS3 setup needs its security cart re-seated all the time.
Even if the board was working last time I had it out/hooked up, when I put it away something "magical" happens and that damn cart must be reinserted.
I thought cleaning the cart contacts would help, it made zero difference.
Is the screen different if you boot it without the cart?
Also, try cleaning the cart and insert and remove it several times.
I've actually been sent a cart to look at with this exact same fault. Does it on the owner's motherboard and my 2.
My 2 SuperBIOS carts work fine so I assumed the cart has either suicided or the EEPROM has become corrupted so I'm planning to replace it with a new one with the SuperBIOS
so if I sent the cart to convert to superbios it may work again?
